Thanks for choosing Wahoo!
How can agents leverage knowledge to help customers?
You can use our Knowledge Capture app to leverage your team’s collective knowledge.
Using the app, agents can:
  • Search the Help Center without leaving the ticket
  • Insert links to relevant Help Center articles in ticket comments
  • Add inline feedback to existing articles that need updates
  • Create new articles while answering tickets using a pre-defined template
Agents never have to leave the ticket interface to share, flag, or create knowledge, so they can help the customer, while also improving your self-service offerings for other customers.
To get started, see our Knowledge Capture documentation.
And before your agents can start creating new knowledge directly from tickets, you’ll need to create a template for them to use. To help you along, we’ve provided some template ideas below. You can copy and paste any sample template below into a new article, add the KCTemplate label to the article, and you’ll be all set.
Q&A template:
[Title]
Question
write the question here.
Answer
write the answer here.
Solution template:
[Title]
Symptoms
write the symptoms here.
Resolution
write the resolution here.
Cause
write the cause here.
How-to template:
[Title]
Objective
write the purpose or task here.
Procedure
write the steps here.
Powered by Zendesk
